Playback problem
  • Playback problem
    Hi all,
    I have Edius 5.01. When I try to play a sequence, sometimes it stops and a message appears saying that it's impossible to execute the play.. (the message I get is in Italian: "Impossibile eseguire la riproduzione").
    The error code is: 0x870307D0. Anyone with the same problem? Any solution?
    sounds like a vst or 3rd party filter issue to me
      There was no VST plugin inserted..........nobody with this problem?
        it might be the same as the "playback stopped" message that some people get with Edius 5...
        http://ediusforum.grassvalley.com/fo...ead.php?t=7723
        Aristotelis Bafaloukos
        BEng (Hons), MSc, MBCS
        Ctrl+Alt+Delete
          and... can you save a copy of the project, or export a part of the timeline?
          Paranova Films
          Cali - Colombia
          http://www.paranovafilms.com/
            remove vst or 3rd party filter in timeline!
            for me : prodad vitascene filter! : failed to export (0x870307d0)
