click for translated features\specification from jap. Edius 4.5
■AVCHD
Import of AVCHD native file
Without using Canopus AVCHD Converter the AVCHD file of Panasonic, Sony and Canon can be imported
■Panasonic
DVCPRO HD 720 59.94p/23.98p over 59.94p
[kiyapuchiya]/it is output enable by way of HD-SDI/RS-422A. * P2 Option is necessary.
Import of P2 AVC-Intra file
The image of AJ-HPX2100 and the like becomes compilation possible.
* P2 Option and AVC-Intra Option are necessary.
Without using Canopus AVCHD Converter the AVCHD file can be imported.
■SONY
HDV 108,024 p/25p/30p
It corresponded to HVR-V1J and HVR-DR60 which are optimum to the digital cinema. With HVR-DR60, import/direct compilation is possible the file which is cut off in the middle of GOP by the restriction of file size as 1 clips. (During patent applying)
■JVC
HDV 720 59.94p/50p
It corresponded to the HDV format of JVC entirely.
■Grass Valley
JPEG2000
It corresponded to reading the JPEG2000 type which with the digital media cam coda “Infinity” of Grass Valley has been adopted. * Standard it is loaded in the turn key system.
The cooperation with DAW/After Effects with AAF
AAF (Advanced Authoring Format) it corresponded to import/export. With the composition software of DAW and After Effects etc of Pro Tools and the like exchanging the data becomes possible
Accelerating HDV/MPEG output
Compilation operation only the place where it does is encoded corresponded to “segmented encoding”. In order to be sufficient for encoding processing of the necessary minimum, XDCAM * 1, HDV * 2, it is possible to accelerate the output of MPEG2.
* 1 XDCAM Option are necessary. Only 108,060 i/50i format segmented encoding possibility. 24p/25p/30p becomes full encoding.
* All format of 2 JVC, Sony/Canon 24p is not yet correspondence
Menu attaching DVD compilation function
Added “Canopus DVD Creator” to the x porter of EDIUS. Until now, it was possible directly to draw up DVD from the time line, but from version 4.5 it reached the point where it can draw up DVD of the menu attaching. Following to wizard, it just operates simply be able to draw up, also the various templets are beforehand prepared. Not only PCM also AC3 is selection possible in sound.
* Number of installed capacity of AC3 channels depends on project setting. In addition, the license of Dolby Digital is limited to private use. You cannot use in commercial business.
Adding user profile performance
It reached the point where the setting and window layout of EDIUS can be changed every user. (Hardware setting [ehuekutopurisetsuto] is excluded)
It calls the compilation environment where is suited for the respective editor instantaneously even with the environment where the group of editors operate one system and/it is possible to change.
It corresponds to the other companies make controller
It corresponded to the controller “MKB-88” for the video compilation software of Musashi corporation make. It moves to nonlinear compilation linear like with the controller which has the operativity of Jog/Shuttle, smoothly, it does the fact that high productivity is shown.
In addition, it corresponded to also Behringer corporation make fader controller “BCF2000
It corresponds to other companies make [terotsupa]
It corresponded to [terotsupa] “VZ50” for EDIUS of the freon TEX corporation make. * Frontec Option is necessary.
In addition, the data of the canvas corporation make SST series lining up the option “SST Option” which is made enabled anew. At the broadcasting station and the like the work flow whose efficiency is good at the time of using, can be actualized.
■Canopus Video Out Plug-ins belongs usually
Former Adobe Photoshop, After Effects and NewTek Lightwave3D (ver.9) adding,
It corresponded to ●Autodesk Maya 7 ●Autodesk 3ds max 8 ●Autodesk Combustion 4 ●Bauhaus Software Mirage 1.5a usually. Real time video output from these software becomes possible.
* This corporation make hardware whose video output is possible is necessary
It corresponds to [kiyapuchiya] with of ■DirectShow Device
Using the hardware which corresponds to DirectShow, with EDIUS [kiyapuchiya] it becomes possible to do. Being able to connect DirectShow Device other than Canopus, make Takasina rank with Canopus HQ Codec [kiyapuchiya] it does and it is possible to compile.
* It is not something which guarantees that it corresponds to all DirectShow Device.
you wish a info from japan >> call europe\austria\vienna .... old Hans
■AVCHD
■Panasonic
■SONY
■JVC
HDV 720 59.94p/50p
■Grass Valley
JPEG2000
