DV Data Code Display
  • DV Data Code Display
    DV embeds data code which can be displayed on the camcorder or player. Is there anyway to call up this information and display it from the timeline? I would like to be able to pull the date/time off the video and display it when needed.
    Go to application settings-> customize-> put the tc display to date and time and you have it.
      Thanks Steve! I will give that a try.
        Thanks Steve. Tried what you said and it works great!
          Is this just for 4.0 and later? I can't seem to find this in 3.6...
          Brad
            correct, date\timestamp from records => only in 4.0 and upward........
              Thanks!
              Brad
