Edius 5 and transitions..
  • Edius 5 and transitions..
    Anyone had this when doing a same track transition (any inc. simple dissolve)
    'THE DATA NECESSARY TO COMPLETE THIS OPERATION IS NOT YET AVAILABLE"
    then the transitions fails to appear.
    My source stuff is MPEG 2 off camcorder - was all working fine the other day. any ideas?
    So are the clips in question, saved or captured to a hard drive on your system?
      Saved - my camcorder throws out ready made MPEG-2 files which up until today have edited fine.
      I am now thinking maybe a plugin is to blame somehow? HEROGLYPH - as i installed that today but havent used it yet
        I would certailny try uninstalling it and then see if the transition works. If so, reinstall Hieroglyph and check the transition again.
          Thanks PJ for the suggestion - I found it was my own fault - I had a music clip on another track and synch on - this stopped the clips from rippling up.
          solution was turn synch off (or I could have used extend clips for same track trans)
