Hi guys... I have been watching the videos of instructions on transitions and i have read the booklet too... however i am faced wiht a problem
the instructions provided dont work for me
it says when you cut *c* a clip... and the next clip is beside it,
drag the transition to the timeline.
then hold *alt* while you drag the transition as long as you need it...
this is not working for me!
does this have to be done in multitrack?
... whether i do it on single track or multi track it seems to only let the transition last 1-2 seconds
is it more customisable?
cheers
cheers
