V5 Smooth Timeline cursor
  • V5 Smooth Timeline cursor
    So how does your timeline cursor behave? Is it jumpy, smooth, sticky?
    does it depend on whether or not the buffer is filling?
    Mine hops, jumps, and sticks, sometimes does not move untill buffer is full,
    it does this even when playing back in realtime without any loaded tracks.
    Paul
    Paul,
    Oh dear, this seems to be similiar to jumping cusers that occured in earlier versions of Edius 1 or 2 I believe. With out access to the old forums I can't remember what caused it as I never suffered.
    Fortunately I have just upgraded to five on a similiar system to yours and all appears ok. DVC at Portslade did the upgrade as I had a new graphics card and a single 1000 gig hard drive fitted at the same time.. Maybe somebody on here can remember and post the solution.
    Regards
    Mick
    Intel i7 6700k, Gigabyte GA-170-HD3 motherboard, Edius pro8, windows 10 pro, 16 gb ram, 256gb SanDisc ssd system drive, Geforce GTX960 graphics card, Blackmagic Intensity Pro4 video card.
      I also have the same effect on my Vista laptop, I'll check with Ringo tommorow as DVC are putting a dual quadcore together for me - maybe it's just needing more grunt.
      Paul
        Hi Paul,
        Having given it some thought, graphic card problems come to mind, but I can't be sure.
        regards
        Mick
          There were some reports of this happening earlier in E5. I don't know the status of it at the moment, but I think it will be fixed in the coming update.
