Manual "localize" function
  • Manual "localize" function
    I've reported this before (old forum) and reported this as an issue, but perhaps someone has found a solution meanwhile: is there a way to disable the automatic localize function in Edius in order to get the default English interface?
    On my system the automatic localize function produces an interface mixing 3 language.
    Edius X - Edius 9.52 Pro - Win 10 64 - AMD-Ryzen 9 3900X - 32 Gb DDR4 - ASUS-PRIME X570-PRO - Nvidia GeForce RTX 2070 SUPER - SSD M.2 1000 Gb system + 3 x 3 Tb storage - 2 x 23" Full HD Monitors - M-Audio Studiophile AV40
    question: you speak german ????
    a) with 3 languages .... it looks for old rudiment fom old 3.2 or 3.5
    in these old times it needs often to manually deinstall the "localice" per:
    start >> settings >> control panel>> software (wih activate the "view update's") >> "Edius Localice"
    b) with a clean install (without rudiment fom old 3.2 "localice") after 3.5 are only variants with 2 languages known for me.
    c) automatic localize function detecting the language from the setting:
    start >> settings >> control panel>> region + language options
    the most from the UI are (fast removable) to switch over above setting, .. i.e. to " English (Great Britain) "
    d) for a contiune change to english,
    rename in ...\Programme\Canopus\Edius\Localice the folder from your "control panel>> region" language
    i.e. the folder " fra " to " _fra " ...... and Edius will start in english.......
    e) other UI parts are in the "MstrPsDB.tpd" included ..... search for it , and rename it, close Edius + Windows
    new start up, and Edius build it new.....
    Attention, if I remember right..... in the "MstrPsDB.tpd" eventually your "personally individual effekt presets" saved
    they are lost.......
    a) - d) things self found + tested between >> german and english User Interface
    e) is a hint from german support ....Hr Kexel
    please excuse my "gibberish" english, it is a hard work for me, in the strange language.....
    friendly greetings from europe\austria\vienna ...... old Hans
      Ich spreche Deutsch. (& Nederlands, Français, English) Ich bedanke mich bei Ihnen :-)
      I'll try this tonight at home and keep you informed.
        a) => yes, I started with Edius 3.2 and upgraded + localized systematically => probably the Dutch part of the actual interface in Edius 4.24 is a trace of the old localizations.
        b) clean install => no time to try this now => I'll probably try this when 4.5 is available
        c) we've discussed this option on the old forum => it works but in principle but I also need to change the keyboard settings, meaning using a azerty-keyboard with qwerty-setting => no so easy
        d) I've renamed yesterday the complete localize-folder without any effect
        e) no such file on my pc !?
        Let's for better times and a manual localize function in the future.
        Vielen dank, Hans und herzliche grüssen aus Belgien. (next time I visit Wien, we'll drink a beer or more together)
          Here's a screen shot a the professional Edius multilanguage interface.
          You better study languages to use Edius! ;-)
            I renamed today (as test) the complete localize-folder [ only OS runs, before Edius start !!!] => Edius coming up in english, in spite of the OS locations-setting to "german-austria"
            to bet for 1/8 lt. from best "white wine from Grinzing" ....=> it is on your PC ???
            look under "Adresse" at the path from the folders......the key is: the folder "Anwendungsdaten" is a >hidden folder<
            try a new search, with 3 new setting under "Extras" => "Folderoptions",
            end of part 1, => forced from max 4 images limitations ...... :-(((
              continuation\part 2
              and on "Start" => "Search" => open pulldown triangle "More Options" => activate "Hidden Elements searching"
              Example from same PC, with no activate "Hidden Elements searching" .....result: no file found......
              Example from same PC, with activate "Hidden Elements searching" ....result: all file found..... I love white wine from "Grinzing"
              please, excuse my miserable english, I hope my pictures a bit better understandable
              if a helpful user, with english OS, will added the correct english pictures to this topic, .....Your help is greatly appreciated
              friendly greetings from ViennaLowLevelService ........... old Hans
              PS: @ Bart ....you have a "Private Message"..... in german language....
                I found the files!
                And tested your suggestions + I've done some further experiments with language and keyboard settings.
                The shortcut-key were shown in French (see the screenshot above) => just changing the notation from "point" to "komma" for my keyboard solves this matter! The shortcut-keys are shown in English. Incredible.
                The fact that the "system preset"-folder is shown as "systeemvoorkeuren" doesn't bother me so much and can be changed as you explained with the overall language settings + I guess with a clean install it will disappear.
                So thank you for you patience and time, you've lead me to a solution!
