Seems that shift+g doesn´t do anything for me more, I render the clip, and when I playing it back, edius tells med to render it again, anyone have similar experince ?, shouldn´t be that way..
Re Render & Re Render
Version? Shft + G works fine work me. here in 5Steve
That is strange.
I think what you should do is clear all rendered files (render-> delete render files->all files) of that project and make sure the disk that you are rendering to is not full.Steve
Originally posted by Ludde View PostI´ll be backAnton Strauss
Hi, Anton
maybe should have posted in the film forum ;)
Hmm, no go, sometimes the same clip takes 30 seconds to render, then sometimes when i have to re-render it, it takes about 7 minits.....???
Can´t figure out what is wrong, maybe move everything to another disc ?A computer with a lot of stuff in it :)
