EDIUS NX & HDV Capture...
  • EDIUS NX & HDV Capture...
    Dear all,
    I want to use an Mainboard without any Firewire controller.
    Is there any way to capture HDV footage from NX's firewire?
    What if I turned NX to ADVC MODE, start EDIUS 5 and select Generic HDV -input?
    Will it work?
    Thanks,
    Kostas Κ.
    HP Z800 Workstation: 2x Intel Xeon X5660 (12 cores - 24 nodes), 24GB DDR3 ECC, nVidia GTX 960 2GB, Win 10, SSD as Boot drive, RAID 0 for video editing, QNAP NAS for Storage, 2x Gigabit Ethernet connection
    if you install the HDV option board and connect it with the internal firewire cable to the mainboard you can capture HDV as well... you don't need a separate firewire controller...
    ADVC mode is DV only...
    Aristotelis Bafaloukos
    BEng (Hons), MSc, MBCS
    Ctrl+Alt+Delete
      Ok, I'll do that!
      Thank you Aristos.
      Kostas Κ.
