basic ? 3.6 to 5 Edius ?
  • basic ? 3.6 to 5 Edius ?
    Hi....
    I'm an editor not a techo expert.
    I have flex-i workstation/Edius NX HD with Edius 3.61 & procoder 2. I'd like to upgrade to Edius 5 and procoder 3 in the upgrade window (?Dec. 31, 2008). Lke some of the new 5 features.
    But I want to know if my 3.61 timelines will go into the 5 timeline (I have quite a few clients who come back to me to rework projects).....and does procoder 3 still link into the edius project timeline export? And I assume if I did upgrade I'd still be able to edit HD.
    What problems might I run into?
    Regards,
    Sheeba
    Edius 9.3, ProASUS TUF X299 Mark I LGA2066 DDR4 M.2 USB 3.1 Dual LAN X299 ATX Motherboard, Intell Core i7-7820 X Skylake-X 8-Core 3.6 GHz processor, GTX 1070, 500 GB Samsung 850 EVO SSD), 4TB WD Enterprise HD, 16 GB Ram, 2 LG DVD burners, Win10 Pro. Intensity Shuttle. Vitascene V.3. Vistitle 2.8 +
    Edius is forward compatible.
    The only thing that might present a problem is if you had use explode/pro.
    No xplode in edius 5
      Actually, EDIUS is backward-compatible, meaning that EDIUS can accept projects made by previous versions of itself. For example, v4 can load v3 projects, etc.
      It is not forward-compatible, meaning that it cannot accept projects made by newer versions of itself. For example, v3 cannot load v4 or v5 projects.
        Yes demystifier .
        Old project in newer version yes! So I can take an old project FORWARD.
        But you can not take a new Project backwards (to old versions)
        So form the project side you always go forward ? :)
