Does BorisFX work with Edius 5?
  • Does BorisFX work with Edius 5?
    If so does it work in the same fashion as before?
    Brad
    no, I am in contact with Boris and they told me they are still working on a way to overcome the incorrect field render
    so at this stage I would not bother installing Boris
      No not properly, I agree with Anton, don't install at the moment, wait for the fix, shouldn't be to long we hope.
      steve
        Thank you guys, lets hope for a quick fix!
        Brad
          you could force a render of the BorisFX transition with Shift+Q and then change the field order in the resulting clip
          however, changing the field order of the rendered clip in Edius5 fixes the footage of the transition to be field order correct, but this breaks the field order of the actual transition movement, so a page turn will look jerky while the footage that is being page turned looks smooth
          by default, a BorisFX transition in Edius looks smooth as far as the movement of the effect goes, but the footage itself has the wrong field order for the duration of the transition, a real mess
          this problem started with Edius4.5, if you have Edius 3 or 4, then BorisFX works perfect
            Any news from Boris, Anton?
              no news on any fix other than that Boris don't support Edius5 at this stage and don't know if they ever will, they seem very (faul) at the moment
