I have a fairly large project, about 2 hrs. long, E5 is taking about 6,7 seconds to save, I have a dual quad core 2.66 with 4 gig of RAM and so it is not a slow system, anybody finds that E5 takes much longer to save and load than previous version?
Save project in E5
Are you running anti-virus? If so, disable it!Rusty Rogers | Films
SD or HD?
how many sequences?
are there non standard clips on timeline such as mp3, mp2, ac3, wmv etc.
are any VST in use?Anton Strauss
I can confirm that E5 will take longer to open the program, but not too long to open a project. Most of my projects are more than 2 hours and upto 4 hours.Asus P5WDH Deluxe w/E6600 - 4GB Corsair - 8800GTS - 1TB & 1.5TB (2x750GB RAID 0) - Antec P180 + Trio 650W - XP Pro w/sp3 - NX PCIe w/Expansion Card - Edius 5.51
Asus P6T i7 920 @3.6 - 12GB Corsair Dominator - GTX275 - 1.5TB & 3TB (2x1.5TB RAID 0) for Video - Antec P183 + Corsair HX-750W - Win7 - Edius 6.07 - Firecoder Blu - PC3.05.91 - BDR-203 - TMW5 & TAW5
Asus P6T i7 930 - 12GB Corsair - GTX260 - 1TB & 1TB WD Black for Video - Antec P183 + TPQ-850W - Win7 - Edius 6.07 w/HD Spark - BDR-205
My project have 3 sequences, 2 of the sequence have alot of VST, that could be the problem, before E5, I normally send my audio to Adobe Audition for noise reduction, with E5 I use VST noise reduction instead and I think that is the only thing different, I don't have any other format on the timeline except for HQ AVI, BMP, 32bit TGA, Wave and MP3. On my next project I will eliminate MP3 as well and convert them to Wave and see if it would help, thanks for the input.I7-6900K, X99 Taichi, Geforce GTX 1070, Corsair RM850X, Corsair H100 IV2, Windows 10, Edius WG 9.30
mp3 maybe the problem
also, I have not tested the VST on lots of clips, that could also be the problemAnton Strauss
