Does anyone know why with the new exporter in Edius 5 the exported file crashes Premiere Pro CS3 and Adobe Ultra? Any workaround? But if you output thru Procoder they don't crash! Why???
Edius 5 exporter not compatable
Al Caudullo
Explore 3D Productions
"Because the world isn't flat, so why watch it that way?"
3D Evangelist
www.exploreworldtv.com
www.3dGuy.tv
Skype ID: al.caudulloTags: None
I do a TV show using compositing of the virtual set. I shoot using OnLocation and edit in Edius. The next step is to import the files to Adobe Ultra CS3. When using either Edius 4.6 or Edius 5, making "Canopus HQ fine" files, Adobe crashes with an unexpected error! I was hoping this was just a transitional problem with Edius 4.6, but it still exists in 5! But if you export using Procoder then there is no problem with the files. Also I have noticed that the Procoder files (3,798,939)are smaller then the Edius 5 Exporter (4,382,236)files! Both from the same timeline!Al Caudullo
3D Evangelist
www.3dGuy.tv
