Prodad Vitascene transistions between PC's
  • Prodad Vitascene transistions between PC's
    Today I was going to work on a project I had been editing on my desktop PC using the laptop.
    Edius 5 and all the add on's are installed just the same as the desktop. However when the project is loaded the transitions are different to the ones on the desktop.
    I can only assume that something is re-set somewhere, can I just copy a file from the desktop to set the transitions as they should be?
    Any idea's anyone?
    Software:
    Edius 8.5 Workgroup
    NewBlue FX
    Hitfilm Ignite
    Vitascene 2
    Newblue TitleMotion Pro
    Smartsound 5.8
    Desktop:
    MSI Z170A M5 Motherboard, i7 6700K 4Ghz, 32GB DDR4, NVIDIA 970 4Gb, 240GB Boot SDD, 500Gb Video SSD, Windows 10 Pro 64bit
    Laptop:
    MSI GS60, 4K UHD, Intel i7, 16Gb DDR3, Nvidia 970M 3Gb, Windows 10 64bit
    Cameras:
    Panasonic HC-VX870 4K
    GoPro Hero4 Black
    Panasonic GX8 (Stills & Video)
    Garmin Virb 360
    I assume it has to do with the lap top not being able to handle GPU effects, and are therefore not available.
    Are some effects replaced by a standard dissolve ? than this is the case.
    If not than others need to chime in who actually have the software, Edius 5 that is.
    Still waiting for HDspark to become available, then i'll go for it ............
      nope.. laptop is powerful enough and effects do work. for some reason Vitascene transisions had been set to a default, however i discovered if I opened the settings dialog box the transition was correct. Closed it and sure enough ALL timeline transitions are as they should be....
      Weird ;)
      Software:
      Edius 8.5 Workgroup
      NewBlue FX
      Hitfilm Ignite
      Vitascene 2
      Smartsound 5.8
      Desktop:
      Laptop:
      Cameras:
      GoPro Hero4 Black
      Garmin Virb 360
        Yeah thats Vitascene for you,
