I found a very simple way to install Titlemotion Pro. Before removing Edius 4 to install Edius 5, copy the Titlemotion folder from the program files Edius 4 folder. Then remove Edius 4. Next install Edius 5 and copy the folder into the new Edius 5 folder. Open Edius 5 and there it is Titlemotion Pro! Works great so far!
Titlemotion Pro
Titlemotion Pro
Al Caudullo
Explore 3D Productions
"Because the world isn't flat, so why watch it that way?"
3D Evangelist
www.exploreworldtv.com
www.3dGuy.tv
Skype ID: al.caudulloTags: None
Not that I have Edius v5 or the HDStorm yet, but are you saying the disc's installer won't let you install into an Edius v5 installation?
I was just looking at my TitleMotion Pro disc yesterday and was wondering the same thing - will it still work.
XPlode Pro v4 also - I see no mention of that around this parts!
-Will
Originally posted by aldigitalguy View PostThen remove Edius 4. Next install Edius 5 and copy the folder into the new Edius 5 folder. Open Edius 5 and there it is Titlemotion Pro! Works great so far!A lonesome traveler looking for lost tribes around the world: https://www.youtube.com/channel/UCdv...DrZCaaw/videos
CPU: Intel i9 7940X
SSD Drive:
Please help TMP won't save my titles, and I have a deadline
I am producing TV programmes, preaching the Gospel on TV, I need to produce titles with scriptures, so there are many. If I create such a title, TMP does not save it under the name I type in, but under a random numer: just "3" or "46". At first it worked if I saved it in a different location, like another hard drive. But now nothing works. Please help. I don't know how to get it to work. I have Edius 6.02 and Titlemotion Pro. Thanks
EDIUS 6.02 has saving problems
be sure to apply update 6.07 (free)Anton Strauss
