Hi, im editing my 4:3 DV format documentary. When i trying to put a clip on timeline, the clip is placing normaly on a VA channel which i want to put, but at the same time there is an extra twin audio track and its placing other VA channel! You can see it on the screenshot pic. Please help!
Audio track is disappear! Please help...
Last edited by murat unal; 10-10-2008, 07:46 AM.1. Intel D5400XS mainboard, GTX660, Dual Xeon X5450 CPU, 1 TB + 2X2 TB, 8 GB Ram, Edius NX for HD, E7.4, Win7 64 Bit.
2. Asus X99 Deluxe, Geforce GTX 770, Intel 5960X 3.0 GHz, GSKILL 32GB DDR4, 250GB 840 EVO + 2X4 TB, 2X27" Philips IPS, 26" Samsung TV, Win7 64 Bit, E7.4 and HD Spark.
- EX1R, HXR-MC50E, 5D Mark II, Lumix GH4, Hero4 Black.
- Rode NTG2, NTG3 and lavalier mikes.
- DJI Phantom-2 with zenmuse H3D.
- Sea&Sea housing for 5D Mark II, Ikelite housing for Sony HXR-MC50E.Tags: None
there are many things that can cause this, I list some common ones
1. you clicked the little V on the left of the track, this means the track will only accept video
http://www.videoproductions.com.au/edius5/no-audio1.png
2. you mapped a track, right click the little A on the left of timeline and then click clear all tracks
http://www.videoproductions.com.au/edius5/no-audio2.pngAnton Strauss
as seen in your screenshot, you mapped the tracks to a1 and a2
clear all tracks as per my screenshotAnton Strauss
It seems I am behind Anton today...;-)
Anton has the answer with the clear all tracks. If you notice the little 1 and 2 on the side of your tracks by the audio, they indicate that you have the different channels mapped there. Clear all tracks and you should end up with one stereo track on VA1 if that is where you drag your clip.
I fixed the problem, thanks guy, i love this forum... :)1. Intel D5400XS mainboard, GTX660, Dual Xeon X5450 CPU, 1 TB + 2X2 TB, 8 GB Ram, Edius NX for HD, E7.4, Win7 64 Bit.
