Edius 5
Install from Upgrade-CD \ fresh install, behind format the disk \ new OS \ no other applications
QT player 7.5 per automatic install from Upgrade-CD
Projectsetting: OHCI SD PAL ....720x576 .......4:3 ......48kHz .....2ch
Applicationsetting >> (default) Source Settings: RGB -Clip = white .....and YCbCr-Clip = superwhite
on timeline: color bar i.e. SMTPE
on vektorscope: colorrange = 16 \ 235
behind export as DV avi (without MSDV) = colorrange 16 \ 235
behind export as DV avi (with MSDV) = colorrange 16 \ 235
behind export as QT-DV = colorrange reduced to 25 \ 215
detected all per vektorscope,
if you have eagle eyes, you can see already the difference on thumbnails in the bin.....
I am alone with this ????
Please can any "helpful guru" trying this problem, and replay ???
friendly greetings from europe\austria\vienna ....old (but not morbid) Hans :-)
