Strange transition problem
  • Strange transition problem
    This is a new one on me:
    I have been putting together several clips one one time line (as I have for over the last 8 years using Canopus/GV products exclusively). When I make a simple transition or dissolve I get a blue screen in my timeline! In the information pallette I get the message that "this transition does not have a set up". So, no matter what transition I use it disolves from a blue screen to the video and back out. Any suggestions? Thanks!
    that is indeed a strange one
    does it also happen if you start a new project?
    does it happen if you place cursor between 2 touching clips and press Alt+1?
      If you apply the transition to the keyer track of one clip (instead of putting between two adjoining clips) like AB style editing, does the same thing happen?
        I've seen this. I found that if I click away from the transition then click on the transition I am able to open the properties for the transition. It's as if the transition looses the focus when applied.
        Camera: Sony HVRZ1U
        Software: Edius 5.11, ProCoder 3.05.91, Imaginate 2, DVDit Pro HD
        System: Supermicro X7DA8, 2 Dual-Core Xeon (5060) 3.2GHz, 4GB RAM, (ST3750640AS) 750GB x 2 SATA
        7200RPM RAID 0, PNY NVIDIA GeForce 9600GT (512MB), Dell UltraSharp 2407WFP, WinXP(SP2), Edius NX w/ Bay and Expansion Kit
          Strange Transition Behaviour
          Thanks for all the input.
          What I discovered was that even though I had "cut" the 5 second leader footage from the clip, it kept including it in the transition. What I ended up doing was cutting an additional 5 seconds from the original clip to get rid of the intro blue footage. I guess I never had any 5 second leader footage to deal with before. I could also just rename the cut clip and try it that way. All is good now.
