problems when capturing with edius 4.6
  • problems when capturing with edius 4.6
    please some help, when I want to capture some video clips I do not know how to chose where to save the captured clips, every captured clip goes to the drive C but I need to send it somewhere else.
    capture clips usually go where you save the project file.
      Pick a big drive with not much on it, make a new folder and use this.
        Go to Settings>Application Settings>Deck Settings and then tick the box for Confirm Filename and Before Capture. This will allow you the choice of where to capture the files.
          Thank you very much !!!
          Well people thank you very much for all your help, THANK YOU FOR YOUR COOPERATION hey great thing there is a forum dont you think?
