Howdy folks... it' been a while since I've edited and I've run into a problem.
Edius NX for HDV + Expansion, Edius 4.61.
I am having a weird problem that I don't recall seeing before... (or if I did, I can't remember the fix).
I have an animation (rendered to frames... not fields) that I created that has arrows moving across the image. The other parts of the image are basically static. Edius 1280x720 project is displaying the HQ file such that the arrows are all doubled with double-vision.
If I inspect the frames that were rendered by the 3D program, they are perfect and crisp. If I inspect the rendered frames that then came out of the compositing program, they are perfect. If I inspect the resulting HQ file in a media player, the arrows appear perfect. But when the HQ file is in Edius, the arrows are doubled for some reason.
I checked my settings and the video overlay is set to display frames. Tried it on fields for grins but it made no difference.
Any idea why I've got double-vision on these arrows?
Thanks!
Thanks!
