Max size still in layout tool?
  • Max size still in layout tool?
    Has anyone tested/discovered the maximum size still image that can be used in the latest E5 layout tool?
    According to its FAQ, Imaginate uses 8MB of RAM per magapixel and has recommended amounts of RAM depending on the megapixel count of the largest imported image. What image size limitations apply in E5 and what controls them?
    Is there a case for adding RAW images, such as DNG, to supported formats?
    DVC laptop: W870CU i7; 17.3" 1920x1080; 2x 1TB 7200rpm SATA notebook drives; Edius 8.5WG; Windows 7.
    I try to load a 5700X3700 and I get black, no time to experiment so I just fire up Imaginate, it would be nice if it could load something atleast this size, for us that do pan and zoom on a HD timeline, this is the size that we need.
      I can tell you now - 4000x4000 pixels (ie. 16megapixels)
        Thank you - that is useful to know.
