OHCI and Edius 5
  • OHCI and Edius 5
    I am getting closer to a new system and Edius 5 upgrade. Is anyone out there using Edius 5 only with OHCI? If so, how are you monitoring it for playback with good sync from Edius HQ projects?
    Hudson Valley, NY
    i7 8700K @ 3.70 Ghz/16 gb RAM
    windows 10
    284 gb SSD boot drive
    2 TB work disc
    2TB storage disc
    EDIUS 9.52.6031
    In HD, there is nothing but GV cards.
    The tiny card : HDspark will be the cheapest (12/2008).
    Marc
    System : W7 Ultimate - MB: Asus Z170 - I7 6700K - Ram 16 Go - SSD1 256 Go (OS/log) - SSD2 1To (rushes) - HDD 4To (save) - Nvidia Asus GTX970 - HDspark - Edius WG 9 - Vistitle 2.6 - Robuskey - Mercalli4 - Neat video - Ignite - Hitfilm4Pro - AV : Eset Nod32 - Others : Moniteur Sony 32-EX500 - Cam : Sony EX1-R - 2 x Sony PXW-X70 - 1 x Pana GH5
    Edius in France
      OCHI is 100% rock-solid.
      Sound from sound card is perfect.
      Don't expect any improvements on monitoring through OCHI... it's still SD.
        SD is OK for monitoring, as long as it's in sync.
        Hudson Valley, NY
        windows 10
        2 TB work disc
        2TB storage disc
        EDIUS 9.52.6031
          When you say Sync I assume you are referring to audio/video.
          1) PC monitor/soundcard are perfect.
          2) Firewire audio/video are synced.
          OCHI timeline lag is probably still there, so don't expect to combine the two.
          Not really an Edius problem, it's an OCHI problem.
            now I'm a bit confused. My expected process would be to input as HQ, edit on an HQ timeline, and output via OHCI (firewire) to a firewire capable deck or DVD player and then to a monitor...Will I experience a lag between audio and video (out of sync) playback on the monitor in this configuration? Or will I have to rely on computer screen playback for in-sync audio & video playback?
            Hudson Valley, NY
            windows 10
            2 TB work disc
            2TB storage disc
            EDIUS 9.52.6031
              If you monitor audio and video from OCHI you'll be fine.
              Don't expect to monitor video from OCHI and audio from your soundcard (or vice-versa).
              OCHI lag has been overcome in some NLE's by injecting a timeline lag.
              Canopus would rather sell you a card (and I'd rather buy one) for monitoring. If only they'd make one for Expresscard/34 slots... laptops would be smokin' good!
                My new laptop comes with a built in eSATA II port plus a Express card slot, so a express card one would be perfect, total portable solution.
                  sounds like my plan would work.
                  Hudson Valley, NY
                  windows 10
                  2 TB work disc
                  2TB storage disc
                  EDIUS 9.52.6031
                    Originally posted by Rusty View Post
                    OHCI lag has been overcome in some NLE's by injecting a timeline lag.
                    Yeah, but that's not necessarily accurate, just like using the graphics card for preview output. Close, but if you need exact, you need the appropriate tool for the job.
