Been working on a V5 Project. I was using the new Izotope VSTs. Those work great...sort of. I started working on the project again today and one of my audio tracks already had a Multiband Compressor added along with a graphic equalizer. I still needed to fix it up a little so I added the AudioRestore per Anton's instructions. It really cleaned up the audio....problem is now Edius crashes alot. I deleted the Audio Restore VST and now all is stable again.
Seems when I added the 2 Izotope VSTs Edius had problems. Individually they worked great. I know I could render the audio file, replace and then use another VST to fix the problem. Not sure if any 2 of the VSTs affect it the same way. I had enough crashes and restarts that I don't want to experiment with it.
I just thought I would report that little quirkiness when using the VSTs.
