Edius 5 & TM Pro from edius 4.0
  • Edius 5 & TM Pro from edius 4.0
    I have the original TM Pro disc that came with version 4 of Edius. I have uninstalled Edius 4.6 and have installed the full version of Edius 5 which came with my new HD Storm board.
    How do I install TM Pro for Edius 5. When I run the install it says it cannot find Edius.
    Another question, Do I need a serial number for TM Pro? if so im out of luck as I have no idea where it would be.
    Best Regards,
    Allan
    PS: I love the ability to directly send the timeline to encode for the Apple TV, the quality is Great!!! Well Done GV on this!!!
    Allan,
    The answer from Kenneally (GV): "HDSTORM/HDSTORM Plus does not include TMP."
    So you can not use the TM pro from previous Edius to install in E5. Maybe someone will know the way to do it :-).
      Best Regards,
      Allan
      when you uninstall Edius 4.6, untick TmPro so it won't be uninstalled
      install Edius5
      copy paste the Tmpro folder from Edius4 to Edius5
        Must I uninstall 5 then re-install 4.6 then install 5 again? I presume so, just im feeling lazy.
        Regards
        Allan
        PS: Maybe its the alcohol making me feel tired and lazy!
          After install Edius 5,
          take the CD provided in the package : "TMP upgrade for V5" , install it.
          And, after a few seconds, it asks to put the original TMP (from V3 or V4) in the DVD player.
          Work in progress ...
          You don't need a serial number for TM Pro.
          Marc
          System : W7 Ultimate - MB: Asus Z170 - I7 6700K - Ram 16 Go - SSD1 256 Go (OS/log) - SSD2 1To (rushes) - HDD 4To (save) - Nvidia Asus GTX970 - HDspark - Edius WG 9 - Vistitle 2.6 - Robuskey - Mercalli4 - Neat video - Ignite - Hitfilm4Pro - AV : Eset Nod32 - Others : Moniteur Sony 32-EX500 - Cam : Sony EX1-R - 2 x Sony PXW-X70 - 1 x Pana GH5
          Edius in France
            No TMPro CD in Edius 5 only from the previous version of Edius. atleast that's what my package contained.
            Allan
              I kinda doubt that TMP for E4 will simply work with E5 by copy/paste.
              I did find that un-ticking TMP during uninstall of E4 simplified installing TMP for E5.
              No disc insertion of v3/4 TMP required!
              Probably no help to you. :~/
                Originally posted by Rusty View Post
                I kinda doubt that TMP for E4 will simply work with E5 by copy/paste./
                worked fine here
                  Yes, it work fine for me. just simply copy/paste.
                    Hi Alan, how're you doing? Where did you get your HDStorm from? I want to get the Edius 5 upgrade but my dealer in Singapore can't even get a reply from the distributor (Convergent) regarding when they will be bringing it in. The local support here for Grass Valley is non-existent (If you've found a better lobang than I have, please share).
                    Richard
                      Allan
                      I have a CD extra for TMP in my package Edius 5 (it seems an upgrade for V5).
                      Marc
                      Edius in France
                        Strange, some of us received TM with Edius5 and others not...WHY ????
                        But here my old version works...who knows the difference between the 2 TM
                          Long time no hear Richard. I have a personal friend who works for convergent also the son is also a member of Laguna golf club of which im on the committee. If you want me to make some calls for you let me know. Call me on my mobile 94509730.
                          Cheers,
                          Allan
                            Allan, you might want to take your mobile # off of the post. I would suggest a PM for a bit more security
                              worked fine here
                              Hi
                              Can i install ev4 in new system with TMPro then install version 5 without uninstall TMPro
