Edius 5 and Vista 64 bit
  • Edius 5 and Vista 64 bit
    Hi !
    Full HD editing requires more resources and power.
    Would Vista U 64bit and Edius 5 give more power and resources ?
    Any experiences.. ?
    I'm running Supermicro DAE7 with duo Quad intels , 4GB and 3Ware 9000 raid 6TB, FX 3700 and XP32 now.
    BR,
    Deepcore
    Finland
    Supermicro 2x Quad-core 5450 3GHz, intel 5000X, 12GB RAM, 12TB, Edius 6.5 HDSpark, Win8, 3x24" Samsungs, E-Mu 1616, Nvidia FX3700
    Sony Z1 & F-350, Canon 1D X, Panasonic HPX 3000 + Amphibico housing- Inspiration Vision Trimix.
    I doubt it would improve anything, HD editing works fine here on XP 32bit
    however, in Vista 64 you may have more software apps open if you have lots of Ram
      At the moment Vista x64 is ready for real work........however if you have XP 32bit and don't need RAM above 4GB, then use XP SP3.
      By the time SP2 rolls out for Vista, I am sure everything will be as good as XP SP2 was.
        Just placed order of Vista 64 Ultimate. No Risk, No Fun !
        I also use Photoshop CS3 for huge panorama pictures.
        XP SP3 runs out of resources when merging 5-6 pictures taken with Canon EOS 1Ds Mark III.. (need 18 pics merging)
        I'll give you performance results when clean install is ready (couple weeks)
        -DC-
          you will have to add Photoshop CS3 (EXE file) to Data Execution Prevention in Vista 64bit to get it to run without problems, Commonly known as DEP.
          cheers
            For production stability I'll make dual boot install with XP SP3 and Vista..
            Thank's for advices !
              cheers
              Steve,
              How does Photoshop CS4 64bit run in Vista 64bit? How does Production Premium work under Vista 64bit? I think you said you have a version of the PP.
              Also, in Vista 32 does it increase the amount of ram seen by the OS as opposed to what is seen by XP? Or do I have to move to 64bit to get 8gbs to show up?
                You need 64-bit OS for > 4GB addressing.
                  Photoshop CS4 is true 64bit software, same as Adobe LightRoom 2 is, when installing it has a look at what system your running and installs the correct version, 32bit or 64bit, can't say much else you will just have to wait a few weeks for the release.
                  Cheers
                    Brandon that is correct about 4GB for Addressing in 64bit systems,
                    Cheers
                      Succesfully installed clean Vista64. All drivers work perfectly and Edius 5 is smooth.. Now waiting for Photoshop CS4 ..
                      And HDStorm to work in V64.
                      Not missing XP 32 anymore..
                      -dc-
                        Great, I am glad you are enjoying 64bit Vista.
                        Cheers
                          Is Edius 5 really 64 bit application ? Looking task manager processes displays [EDIUS.exe *32] like other 32bit applications on list. Without *32 application is true 64bit mode.
                          -dc-
                            It is not a true 64bit application, it is a 32bit application that can run on Vista 64bit.
                            Cheers
                              Steve is correct, it is a 32 bit app.
