Edius 5 is crashing every time it tries to display the thumbnail in the bin on several clips. These clips were captured from CF using the Sony utility and were handled ok by 4.61. Any ideas please? I have already tried creating a new project and re-importing the files without success.
Some clips in bin cause crash after upgrade to v5
Hedley Wright
Partner - Brett Vale Studios
System: Mac Pro 2 x Quad-Core intel Xeon 6GB RAM, nVidia GeForce 8800GT 512MB, 2 BenQ FP937s 19" Wide Monitors, 200 Gb Bootcamp Window XP Pro partition, 550Gb OsX Leopard partition, RAID 0 Video drive 2 x 750Gb WD Caviar | Edius 5.11, NX ExpressTags: None
Originally posted by pjsssss View PostIf you use details only in the bin , does it still crash?Hedley Wright
what do you mean by "import" when they are already in the bin?
do you mean when dragging to timeline?Anton Strauss
Originally posted by antonsvideo View Postwhat do you mean by "import" when they are already in the bin?
do you mean when dragging to timeline?Hedley Wright
Originally posted by GrassValley_KH View PostAny chance of us getting a sample file?Hedley Wright
I have also encountered a similar problem. Fortunately for me I ghosted my C drive before upgrading to vs 5. My media is kept on a separate raid 10 array.
Upon opening an SD project with HDV m2t clips in it that worked fine in 4.61, about half of the m2t clips were reported by Vs 5 as being 'offline' - notably these were all files larger than 5Gb - the smaller ones all seemed to survive OK.
Using E5's restore clip dialogue, although I could identify the clips on the Raid, E5 would not allow me to relink these into the project. After an afternoon's frustration, I went back to version 4 using norton ghost. As I had not re-saved the project file in E5 I was fortunate in being able to re-open the project in version 4 with all clips present and correct.
Is Edius 5 more picky with m2t clips than version 4?
This issue is a real pain and renders Edius 5 unusable so far as I am concerned! A great pity because the ability to zoom into HDV clips in an SD project and maintain resolution was what persuaded me to buy it.Last edited by andrewwhiteley; 11-05-2008, 11:52 AM.Andrew Whiteley
Edius Workstation 9.51 on Intensity pro 4k, Windows 10 pro 64bit, Gigabyte GA-Z170XP-SLI Intel Z170, GTX 750 Ti 2Gb, i7 6700K 4.0GHz, 32 Gb RAM, 'C' drive Samsung M.2 256Gb,
Media drive 2 X Samsung 850 pro 1Tb RAID 0,
Archive media drive Hitachi 4TB
Originally posted by GrassValley_KH View PostYeouch - that's a nasty piece of work with the start and end - lots of green MPEG breakage.
I think that's the issue - EDIUS 5 is simply quitting out in its attempt to read in the file. I'll pass it on to Japan and see what they say.Hedley Wright
I've had a similar Edius crash scenario in v4.x.
Load the project ok and as I scroll down to the problem files in the Bin and >poof!< Edius is gone! The files would play with VLC or Media Player, but the problem was obvious.
I'd been able to scroll to where I can just see the top of the suspect file in the bin and remove it with success. (this takes some patients) Then re-capture. Mostly caused by tape errors. If you're really stuck, maybe try an analog capture :~/. I have.Rusty Rogers | Films
Thanks Rusty. I found the easiest way of identifying the problem files was switching the bin to list view (six files in view at any one time) so it was easy to workout the file number when Edius quit. Then move the file with Explore and delete the offline clip in Edius after restarting.
Analogue ingest is a definite last resort for obvious reasons but, other than reverting to v4.6x would be the only way. At a typical wedding as many as 5% of my clips are affected. These clips all loaded fine before upgrading to v5 so something has changed for the worse with the new version. Hopefully Keneally's post to Japan will produce a solution,Hedley Wright
Originally posted by GrassValley_KH View PostWord back is that engineering have identified the issue, and say that it will be fixed in an upcoming update.
from the bin? - if this is fixed I'll be a very happy man!Andrew Whiteley
