AVCHD ins and outs with E5/HDStorm?
  • AVCHD ins and outs with E5/HDStorm?
    I am seeking clarification of E5/HDstorm capabilities when inputting and outputting AVCHD.
    My understanding of AVCHD is that there is a consumer format (used in Sony/Panasonic consumer cams) which goes up to 17Mbps. In Panasonic terminology these are HA, HG and HE. In addition Canon and Panasonic have introduced higher rate formats which seem to use different codecs and support up to c24Mbps. The Panasonic terminology for this is PH and is offered on their new HMC150 camera.
    Does E5 support all of these formats for input? If not right now, can we expect it to do so in the near future?
    Brandon has posted that E5 supports AVCHD output. Which version(s) of AVCHD are supported?
    The Panasonic HMC151 brochure says that output via NLE systems should be possible to BD (BD video), DVD (AVCHD) and DVD (standard definition). Does/will E5/HDStorm support these three alternative output modes?
    DVC laptop: W870CU i7; 17.3" 1920x1080; 2x 1TB 7200rpm SATA notebook drives; Edius 8.5WG; Windows 7.
    According to my exporter list:
    Sony FH
    Sony FS
    Sony XP
    Sony HQ+
    Sony HQ
    Sony SP
    Sony LP
    Panasonic HA
    Panasonic HG
    Panasonic HE
    Panasonic HF
    Panasonic HN
    Canon FXP
    Canon FXP
    Canon XP+
    Canon XP
    Canon SP
    Canon LP
      Actually with the release of the latest Canon AVCHD camcorder, bitrate is now up to the maxium the format allows, 24mbps.
        Thanks, Brandon, for the detailed reply - that is very helpful.
        The second part of my question concerned supported output, ie BD and AVCHD on DVD. Are you able to comment on that yet?
        There is also another outstanding question about the ability of E5 to capture metadata in HQ (I need date/time information in the bin) from an earlier post. Presumably a reply is still pending on this.
