shoud i have scsi hard disk to work with edius hd card ?
  • shoud i have scsi hard disk to work with edius hd card ?
    hi ,
    i have 2tb sata 2 raid0 on my edius hd system
    should i have scsi to work with hd uncompressed files ?
    is it good quality if i use hq codec to work with hd ???
    thanks alot
    You should be fine and the quality of HQ is very good.
      Originally posted by bashvideo View Post
      hi ,
      thanks alot
      With your current system, can you capture to all of your raid? if yes then you are fine, if no then you might need faster raid card, I used to have Highpoint 1820A card and it only fast enough to let me capture a little over half of my 1tb raid and then I get error saying that drive is too slow, I switch to 3ware 9550sx and now I can capture all of my raid. I don't think you need SCSI.
        thanks alot
          the latest high point controllers are perfect! I have used a few to make RAID5 and stripe volumes with 8-10 Sata drives and they were very fast!!! Better than any SCSI setup I have seen lately....
          Aristotelis Bafaloukos
          BEng (Hons), MSc, MBCS
          Ctrl+Alt+Delete
