So I've edited a project with 1280x720p settings and footage. Now I want to make the properly distorted 720x480 MPEGs for authoring into an 16x9 SD DVD (probably using DVDLabPro).
Is there a particular setting I should look for when outputting from the timeline via PCE or PC?
Or would I be better off rendering a finished HQ file, placing in a different project with different settings?
Somehow, I've got to re-scale the finished project down to the 16x9 SD format and of course I want the best quality.
Thanks!
Thanks!
