Canopus HQ problem?
  • #1
    What version of EDIUS are you running? There was a field-inversion problem on export that was corrected somewhere in the v4.x line.
      change your project setting to SD D1 and it will be upper field first for Pal
      when the project is set to SD DV, it will export HQ with the DV field order of lower field first
