after lots of testing, I am now getting superb results when downscaling using the Lanczos3 downscale filter
Virtual Dub and Edius5 HD to SD
EDIUS X WG with BM Mini Monitor 4k and BM Mini Recorder, Gigabyte X299 UD4 Pro, Intel Core i9 9960X 16 Core, 32 Threads @ 4.3Ghz, Corsair Water Cooling, Gigabyte RTX-2070 Super 3X 8GB Video Card, Samsung 860 Pro 512GB SSD for System, 8TB Samsung Raid0 SSD for Video, 2 Pioneer BDR-209 Blu-ray/DVD burners, Hotswap Bay for 3.5" Sata and 2.5" SSD, Phanteks Enthoo Pro XL Tower, Corsair 32GB DDR4 Ram, Win10 ProTags: None
I can confirm Antons findings, not only is this good with Z1, DVCProHD and HDCam footage, but works extremely well with EX1 material, which is the most dificult to deal with - most NLE's and re purposing software cannot handle the EX1 and EX3's huge detail.
PaulEdius Edits at: http://www.vimeo.com/user781619/videos
Hi Anton,
As the HD area is new to me, do you think the same is working for 1920x1080 25fps footage as well or are other settings required?
I was not able to test it yet, but from recent checks with VirtualDub I assume you save the file as AVI after you made all settings as you described or are you using the frame server?.
I am currently testing Edius (currently using Vegas) and so far I love it as well as the support and knowledge on this forum
Regards, ReneRene van Kleef
Vista Ultimate - Intel Extreme X9650 3GHz - 4Gb memory - NVIDIA 8800GTX 756Mb - Sony Vegas - Moving to HD - Testing Edius 5.0 - Testing VirtualDub
it will work fine with 1920x1080
yes, I save the file as Canopus HQ avi, this allows me to alter all needed settings in Edius prior to mpeg export
I am not going to use the frame server method, because the result produces the wrong black level, the NTSC 7.5 IRE setupAnton Strauss
Originally posted by antonsvideo View Postafter lots of testing, I am now getting superb results when downscaling using the Lanczos3 downscale filter
http://www.videoproductions.com.au/h...dub-hd-sd.htmlI7-6900K, X99 Taichi, Geforce GTX 1070, Corsair RM850X, Corsair H100 IV2, Windows 10, Edius WG 9.30
I tried all bicubic but in Pal at least, I get sharper looking SD when using Lanczos3
I will do more testing and try againAnton Strauss
Lanczos-3
Resizes the clip’s picture using a Lanczos-3 method. Based on an improved version of the Lanczos method in order to be efficient in both enlargement and reduction. Produces a picture more sharpened than the other filtersAnton Strauss
here is a small PAL VIDEO_TS you can burn and test (18mb)
workflow used
1. Canopus HQ sample clips exported to HQ
2. use Virtual Dub to downscale to 720x576
3. use Edius5 standard def 16:9 D1 to correct field order and aspect
4. export with ProCoder3 mastering quality
5. author with DVD-Lab ProAnton Strauss
Click on this link and you can see a few example of what I'm talking about.
let me do some testing with bicubic=.60Anton Strauss
what about us here in the U.S. do we scale to 720 x 480 instead?
And in virtual dub after you apply the filter and scaling, do you output/save as an .avi file or what?
Using the Canopus HQ codec in "fine" mode I exported the file and then opened it in Procoder express and converted it to DV (Standard def 720x480) and it is SLIGHTLY better, but scenes where I put CG/graphics on screen the graphics look bad now.NLE: PC, Gigabyte Motherboard with E6850 Core 2 Duo CPU @ 3.0ghz. 4Gb Ram. GRAPHICS: NVIDIA GeForce GTS250
DRIVES: 4TB raid 0 array connected to AMCC 3ware SATA controller with 518mb memory. Other Drives: Seagate & WD 7200rpm 1TB each
SOFTWARE: Edius 5.5, Adobe Encore CS4, Photoshop and After Effects CS4.
yes, type 720x480
make sure interlace is ticked
set compressor to CanopusHQ with fine
Canopus HQ = avi
open the avi in a standard def DV 720x480 project in Edius
then change field order and aspect, then export with ProCoderAnton Strauss
When I use VirtualDub to downsize a 1920x1080 30Gb AVI file to 720x576 it fails always around frame 2400 (same for various other AVI files). The error messages says DLL initialization failed, video compression error, an unknown error occurred (may be corrupted data) (error code -100)
I created the source files from mt2s footage and rendered/printed as AVI. I used both Vegas 8b and Edius 4.6 to create the AVI source file, both AVI files fails when downsizing by VD.
VirtualDub setting I used:
Resize filter 720x576, Lanczos3, Interlaces)
Sharpen filter 8
Color depth, autoselect and same as decrompression format
Compression, Canopus HQ, CODEC setting fine
Once set, I save as an AVI file.
I tried various compression options but the same problem occurs. I am a bit lost now and I am thinking to do a clean installation of my test machine and hopefully the problem disappears.
Any other suggestions where I can look into ?
Used HW/SW:
Windows Vista Ultimate
Intel QC X9650 3GHz - 4Gb memory
NVIDIA 8800GTX - 756Mb
SoundBlaster X-FiRene van Kleef
is this with the latest version of VD? v1.8.6 (stable)Anton Strauss
It is version 1.8.6, which I downloaded 2 days ago.
It looks like all the memory is consumed. When I try to re-start the save as AVI, it says no memory resources. I just installed TMPGEnc on my test machine to see if this was still worning, when I select Canopus HQ here, the same error occurs. TMPGEnc is running fine on my production machine, but have no Edius installed there as I am still testing.Rene van Kleef
