It is possible to switch audio output betwen NHX-E2 and Soundcard?
Audio output NHX-E2
Oh. Did you read the manual? You have to use the small cable that routes NX's out to the line in of your sound card. Once you do that, all the sound from the NX will be routed to your line out of your sound card.
Right now I have routed my NX out to the line in of my sound card and raised the level from the volume control of line in.
If there is no signal out of the NX then you will not get any sound.
I am still not clear on what you're trying to accomplish.
Are you trying to record something through the NX? I usually start DVCapture (selecting rear NX in) and launch Audition to capture audio. I make sure that Line In is properly leveled.
Plug that cable Dave is talking about, then you vill have the audio from edius and the NX routed trhue the audiocard and your audio app will use the audiocard also: Al audio will be out from the audiocard.Last edited by johannesj; 09-24-2008, 12:16 AM.JoiCam´s
And more
Originally posted by GrassValley_BH View PostIf you're in a hardware project setting, you'll get audio output from the hardware being used. If you're in an OHCI project setting, you'll get audio output from your operating system's sound hardware.
simply go to project settings and change it to use the NXAnton Strauss
