Edius 5.0 Installation
  • Edius 5.0 Installation
    I picked up my E5 today and have everything installed. It all went pretty smoothly, although it did take quite some time as there are so many programs to install. I opened Edius and made sure everything worked before I went on to the next one.
    A couple of things to watch for. You will be asked to provide a serial number from a previous version. Title Motion asked me to put in a disc from my E4. And I wasn't sure if I actually registered Mercalli, but it does seem to be up and working.
    I opened a project that I was previously working on and all went well. I did however backit up before I moved forward.
    So far all is well! I'm pretty much doing SD, but hope to try out some HD footage soon.
    Thanks Grass Valley!
    You're welcome Dianne.
    I must say, I'm surprised the TMP installation asked for the older disc. That's unfortunate, but probably necessary in verifying you are a previous owner.
    It could get hairy though, when we get to people with an upgrade from before TMP's reign..
      I was suprised too.... but luckily I had several copies. So far all is well and I'm enjoying the 3rd party software as well
        You are righ KH. The upgrade includes tmpro regardless if you had an Edius tmpro bundle or not.
        Because people with a EDIUS bundle without tmpro will have a big problem if the installer asks for a previous disk.
          That includes me, I did not want it anyway due to previous problems with TMPro in Premier, and still do not wish to have it and I have 5 on order arriving next week I am told, will keep you informed on how the install goes. Is there an option to cancel it?
          The scream will be loud and clear
          Regards Barry
            If I understand the question....TMpro is on a seperate disc, so if you don't want it you don't have to install it
