Open not finished projects from 4.6 in 5
  • Open not finished projects from 4.6 in 5
    I have a long project (65 minutes) still under work in HD. Is it too bold to install E5 and hope to be able to finish this ongoing project?
    Peter
    Skanoer, Sweden
    Edius Pro 8, Imaginate 2, Intel i7 950 , 12GB DDR3, 5 TB, Windows Pro 10 Creative, 64bit, Encore CS5
    Peter, I have imported huge HD projects with 120 min and up to 500 GB --> it works fine, don’t worry.
    Loading projects in generell takes a bit longer in EDIUS 5.
    Eric
    English is not my native language
    ___________________________________
    System 1:Intel core i7-6700K 4 GHz - ASUS Z170-A - 32 GB DDR4 RAM - Intel HD 530 Graphic - Win 10 Pro - Storm 3G - Blu-Ray LG BH10LS30
    System 2: Intel i7-960 3,2 GHz - ASUS P6T - 12 GB DDR3 RAM - Radeon HD 5850 1GB - Win7 Ult 64bit SP1 - Storm 3G - Blu-Ray LG BH08LS20 - LG GH22NS50
      I would suggest that you save the project with a new name if you go into E5 as once saved in E5 it cannot be opened in E4.6 should you need to go back to that version. Alternately you could open it from the backup file created when it was last opened in V4.6
        Sound advice for opening any project in an upgraded version. Though I save the project under a new name in the old project and then open the newly named project in the upgraded version.
          yes, same here, a copy in the same folder, I can open all my projects in E4.61 and E5
            I usually have multiple backups of the projects but also on different drives and I sometimes zip them up.
            So working on a copy is a smart idea. Either way if this project is REALLY important I would recommend that you finish it in 4.61. Remember that EDIUS 5 is a trial and it hasn't shipped yet afaik. What if the trial runs up accidently and you will be stuck with an non openable project (5 projects don't open in 4.x) where you probably did alot of work in.
              Thank you guys for great advice.
              Peter
              Skanoer, Sweden
                Skall uppdatera inom kort to E5.0
                Windows 10 PRO - 16GB DDR4 Ram - 16TB - Intel Core i7 7700K 4.2GHZ, 8MB Cache - SSD 128 -SSD 250GB - NVIDIA GeForce GTX 1050Ti - EDIUS 8.52 - AE CS4 - 1 LG W2252 - 1 Panasonic 243V - 2st Panasonic HD HC-X920 - 2st Panasonic DVX100B
