Xdcam 700
  • Xdcam 700
    I have an opportunity to use XDCAM 700's which utilise the higher 50Mb/s data rate, is there an intention for this to be supported by Edius 5, and as an output back to disc - currently 35Mb/s is the highest data rate available for output.
    Paul
    Look at the picture it will answer your question. Yes : )
    BTW there is a demo available.
      I presume this is missing on the download trial version of 5 as I find it not.
      OK being a bit sluggish - all found thanks!
      Paul
        Cool :)
        Good to hear you found it.
