Start up progress (odd)
  • Start up progress (odd)
    I uninstalled the trial and applied the full install.
    On startup, the progress bar stops about 15-20% of the way (for around) 20 seconds and then goes immediately to the preset/project screen. It's not serious or anything, just strange that the bar stops and waits, then bamm, I'm in. The trial went all the way accross the screen for me.
    Also, some times the EDIUS.exe *32 process does not stop after closing with my full install, is there a VST or Vitascene DLL to blame like I read sometime ago?
    in my case under XP, it stops for 20 - 30 seconds and then progresses fast all the way to the right
    as for the process not ending, this is caused by vitascene but already fixed in a newer tpi
      It doesn't seem to be causing any real problems loading stuff (so it's just wierd)
      How would i get the newer tpi?
      Thanks Anton
        ProDAD has provided a patch for a new TPI (Version 1.0.37) which works in EDIUS for all VitaScene Versions 1.0.35:
        Eric
        English is not my native language
        ___________________________________
        System 1:Intel core i7-6700K 4 GHz - ASUS Z170-A - 32 GB DDR4 RAM - Intel HD 530 Graphic - Win 10 Pro - Storm 3G - Blu-Ray LG BH10LS30
        System 2: Intel i7-960 3,2 GHz - ASUS P6T - 12 GB DDR3 RAM - Radeon HD 5850 1GB - Win7 Ult 64bit SP1 - Storm 3G - Blu-Ray LG BH08LS20 - LG GH22NS50
          can you do a quick test?
          cut and paste the VST folder to a temp location while Edius is closed
          now start Edius, how is the progress bar doing now?
            That's it Anton.
            Are you sure you aren't on the payroll :)
              Eric
              Thanks Eric. Someone has already supplied the latest to me.
                That's it Anton.
                no, not on any payroll, but the slow progress bar is caused by the izoptone plugins
