Ive had problems with HD footage (720p, 24f) in Edius when I change the project settings to 480i so I can export/print/record the project to NTSC video tape or DVD. The problem I exerience is alot of stair stepping, jiggly lines, anti ailiasing when there are busy patterns or thin lines in the video footage. I understand this is a progressive to interlaced conversion problem. Problem also was there when exporting/converting via Procoder Express. Has this been improved upon at all with Version 5?
Does Ver. 5 downconvert to SD interlaced better?
NLE: PC, Gigabyte Motherboard with E6850 Core 2 Duo CPU @ 3.0ghz. 4Gb Ram. GRAPHICS: NVIDIA GeForce GTS250
DRIVES: 4TB raid 0 array connected to AMCC 3ware SATA controller with 518mb memory. Other Drives: Seagate & WD 7200rpm 1TB each
SOFTWARE: Edius 5.5, Adobe Encore CS4, Photoshop and After Effects CS4.Tags: None
Originally posted by richnation View PostIve had problems with HD footage (720p, 24f) in Edius when I change the project settings to 480i so I can export/print/record the project to NTSC video tape or DVD. The problem I exerience is alot of stair stepping, jiggly lines, anti ailiasing when there are busy patterns or thin lines in the video footage. I understand this is a progressive to interlaced conversion problem. Problem also was there when exporting/converting via Procoder Express. Has this been improved upon at all with Version 5?Cheers,
Stuart.
Originally posted by beachside View PostAnyone compared? Or do we still need the Virtual Dub method?
I keep some really problematic clips just to test this and have given then to people using other programs but no one will confirm either way, interesting
Virtual Dub (free) with 2 simple filters (resize and sharpen by 8) does an unreal job and the conversion is realtime on my PC, meaning a 1 hour HD HQ clip will take 1 hour to convert to HQ SD, then I can encode to SD DVD with no artifactsLast edited by antonsvideo; 09-22-2008, 04:13 PM.Anton Strauss
Originally posted by antonsvideo View PostVirtual Dub (free) with 2 simple filters (resize and sharpen by 8) does an unreal job and the conversion is realtime on my PC, meaning a 1 hour HD HQ clip will take 1 hour to convert to HQ SD, then I can encode to SD DVD with no artifacts
Panagiotis
Widescreen or 3x4?
Anton - when you do the Virtual Dub (which I too love!) conversion from HD to SD - do you usually end up with a 16x9 widescreen letterboxed SD version, or do you crop for a 3x4 SD picture? I've run into more artifacts when I crop it than if I keep the native 16x9 ratio. Even with a slight sharpening and sometimes a small amount of motion-blur. Same with you?
Cheers,
AlanAlan J. Levi
Director
SYSTEM: ASUS P8Z77-VPro mobo, Intel 3770K CPU, 16 Gig Crucial 1866 RAM, Antec 1000W PS, EVGA nVidia 560Ti 1Gig Video, CoolerMaster CPU cooler, LG GGW-H20L BluRay DVD, SPARK card w/23" Samsung 1920x1080 Monitor, OCZ 240GB SSD boot in Swapable Tray & 3 WD Enterprise 1TB video RAID 5 HDD's. 4.5TB RAID 1 Outboard backups, Behringer2000 Audio Fader/Controller
Originally posted by antonsvideo View PostEdius5 is the same as 4 in that regard, hopefully someone is working on something?
Have you tried going from HQ AVI (HD) to SD (MPEG2) in TMPEGEnc X4?Cheers,
Stuart.
Originally posted by beachside View PostHi anton,
Have you tried going from HQ AVI (HD) to SD (MPEG2) in TMPEGEnc X4?Anton Strauss
Originally posted by pgovotsos View PostWhich version of Virtual Dub - the original or one of the mods? Or will any work OK?
PanagiotisAnton Strauss
Originally posted by AJL14 View PostAnton - when you do the Virtual Dub (which I too love!) conversion from HD to SD - do you usually end up with a 16x9 widescreen letterboxed SD version, or do you crop for a 3x4 SD picture? I've run into more artifacts when I crop it than if I keep the native 16x9 ratio. Even with a slight sharpening and sometimes a small amount of motion-blur. Same with you?
Cheers,
Alan
I set destination frame size to 720x576 Pal and leave 4:3 and I tick interlaced and add a sharpen filter set to 8
then when I open the resulting SD HQ file in Edius or Tmpeg4, I change the aspect to 16:9 and change the field order, since Virtual Dub encodes with the wrong field order
the resulting file has no artefacts whatsoeverAnton Strauss
I forgot to mention that I am currently testing to use Virtual Dub as a frame server direct to T4 Xpress for m2v and ac3 encodingAnton Strauss
Cheers,
Alan
I leave the Aspect in the VirtualDub Video "Resise" filter disabled
and with the "Resize" filter selected but not open I select "Cropping" and in X1 and X2 Offset I set to 180 which crops in VD to 4:3
I then convert in the VFAPIConverter open Procoder 3 (Not 3.05) as this will not accept the VFAPI AVI file
Select my source and change the field order to "Upper"
Select the Target, for 4:3 I use Canopus DV and add the Sharpen filter in the Advanced settings with the following preset
Radius of Blur 1.5
Amount of Blend 0.5
Threshold 0
No artifacts and the results at 4:3 are as good as from a good SD camera
Must try Antons sharpen of 8 in VD
Super explanations....
Anton and Barry. I hope everyone has a chance to read your valuable input on these forums. Nothing like experience.
Many thanks...believe me!
AlanAlan J. Levi
Director
I keep hoping for fix from within Edius/procoder. Probably that hope is invain. For some reason, since my source is mainly 1440x1080i 16x9 and my end result is 4x3 SD DVD I have trouble with the Aspect Ratio using the Virdub method.
Would someone post the current up to date steps when down converting from HDV 16x9 to SD 4x3?
RonnieRonnie Martin
Kato Video Productions
