problems with a\b roll HD editing
  • problems with a\b roll HD editing
    Hi..
    i'm using EDIUS 4.6 and was trying to edit a\b roll HD. after a few moments the computer got stuck and wouldn't move untill I reboot.
    my hardware:
    intel quad core
    asus p5k workstation m\b
    2048 RAM
    canopus DVX
    geforce 8800GT 512MB
    btw - the project was opened on these specs:
    generic OHCI HD 50Hz 1440x1080 50i
    AND THE PROJECT WAS NOT OPENED ON THE THE CANOPUS CARD.
    While trying to edit on a much lower specs computer (pentium D, 2gigs) i managed to edit HD a\b roll.
    please help me, i'm losing money! :)
    Originally posted by ragee View Post
    Hi..
    my hardware:
    intel quad core
    2048 RAM
    canopus DVX
    your computer did not get stuck
    what happened is that a little window popped to tell you that playback stopped (because of a dropped frame), and until you click its ok button, the computer won't respond
    this little window if often hard to see due to the Edius color scheme, it should really be bigger and maybe a different color
    you can disable stop playback when frames are dropped in application settings, then you won't have this problem again
      ragee, welcome to the forums
      Anton sounds correct on this one... hit the Spacebar to clear the dialog box.
      Now make some money!
