AVCHD conversion problems
  • AVCHD conversion problems
    Hi all,
    I'm considering returning to EDIUS after a few years running Premiere Pro. Just downloaded the E5 demo. Impressive!!
    I have 2000 AVCHD clips in a folder and want to convert them to Canopus HQ. I first tried to do it from EDIUS via the "Convert->File(batch)" command. However the "Online (fine)" codec settings are used...I'd rather use the "Online(standard)" settings to save ~40% space.
    So I installed AVCHD2HQ, set the codec options to "Online(standard)" and thought I was home free. Unfortunately, when I drag more than about 35 clips onto AVCHD2HQ, I get the cryptic error:
    "The data area passed to a system call is too small"
    Furthermore, if I right click with more than ~30 files, there is no "Convert with AVCHD2HQ" context menu option. Smaller batches of files work just fine. Any idea why I'm getting this error?? Anyone else experience it?
    If I can't resolve this, I'll have to bite the bullet and use EDIUS to convert the files at the higher bitrate.
    Kris
    In EDIUS, what setting is the HQ codec set to? (Settings>Hardware Settings>HDV)
      Under hardware settings, everywhere I can set a HQ codec setting I have it set to Online(standard). The settings in the Convert feature seem to be presets.
      Perhaps I'm missing something. I hope to be corrected :)
