Question regarding HDSTORM Plus in/out
  • Question regarding HDSTORM Plus in/out
    Press release/product page says the following:
    A bundle of HDSTORM and (5.25-inch) bay, called HDSTORM Plus, will also be available. The bay not only features additional connectors for HDMI devices, but also input and output connectors for analog HD/SD component, S-Video, composite and unbalanced audio; this helps those still working in analog to make the transition to digital and HD production.
    When I look at the bay I can't see y/c and composite?! Please clarify.
    For composite, plug into the Y (green) terminal, and choose the appropriate profile.
    For S-Video, you use the supplied miniDIN adapter cable and plug into the three (Y, Pb, Pr) terminals.
      Thanks! Have to call customer right now! :)
        Will that bay hook up to the NX? I know the NX has extra ports on board,
          No. HDSTORM only.
            No. HDSTORM only.
            Part 1
            Does the HD Storm process information any faster than the NX or SP, or is it basically the same processing with HDMI capabilities?
            Part 2
            Is the HD Thunder going to have a BOB or just a bay for a breakout?
            I would hope that it would have every connector available at this time on board.
              Firewire interface???
                Part 1
                Part 2
                1. No, it's the same - all three edit HD with total reliance on system performance. They all provide sync'ed output to a monitor
                2. No BOB or bay. But it's not like there's no SDI-based multi-I/O solutions out there...
                Covered in another thread - no FireWire for HDSTORM/HDTHUNDER/HDSPARK
                  Gotcha! One could only hope.
                    HDstorm for RT effects
                    hi,
                    so, it´s real, the canopus NX, SP or HDstorm, just work as input/output board,
                    i supose that canopus board may help my pc to edit faster using the capabilities of the boards. i usualy edit with edius, and i must convert all to DV codec. ´cus i can´t edit any compress video.
                    but, a few years ago, i saw a core 2 duo, using a NX express, and it could handle a lot of streams and effects in RT. why???
                    i read in the forum, that using a board for monitoring help the cpu, but just let it free of thinking about output the video.
                    so, it´s the same using an OHCI hard for monitoring by firewire???
                    thanks
                    read my other post of today
