Help with v5, Please-Timeline Lock
  • Help with v5, Please-Timeline Lock
    Sorry if this is a dumb question, it has me baffled. I have Edius v5 demo installed. I've imported a clip to the bin and placed the clip on the timeline. I, then, right click the timeline track and select "Layout" from the drop down menu. EDIUS displays a small padlock on the mouse cursor and all commands are locked out, I can't even shut down. I only get a pop-up which says "Close all dialogs", but, nothing else is open.
    Can anyone suggest why this is happening?
    Thanx
    Chalchihuitl Productions
    Sony EX1-Canon 7D DSLR-Flash XDR
    HP8730w/HP8740w/Intel X48
    most likely your layout window is hidden somewhere outside the region of your monitor(s)...
    the easiest way I can think in order to fix the problem is to create a new user profile...
    Aristotelis Bafaloukos
    BEng (Hons), MSc, MBCS
    Ctrl+Alt+Delete
      layout is by default in the information box all the time now of course. Click that and see if it also shows a padlock
      E9 PRO ,Intensity Shuttle capture Nvidia 650 TI LG 3D Monitor HDMI Win 10 PRO 64 Bit.Vistitle 2.6, Robuskey. ASUS Z370 I7 8700 16 GB Hyper X black RAM 250GB 960 EVO. 2 ITB Disks
        Aristotelis...
        Thanx. I reset my profile and that fixed the "invisible" Layout window to where I can see it.
