Is there any hope that Edius 5 will be compatible with DVStorm (the original version)? Or if I want to use E5, will I have to give up my trusty DVStorm and move on? :-( Or, is the HDMI board compatible with a system that has the DVStorm card?
Edius 5 and DV Storm
This topic is closed.
Originally posted by Tobe View PostIs there any hope that Edius 5 will be compatible with DVStorm (the original version)? Or if I want to use E5, will I have to give up my trusty DVStorm and move on? :-( Or, is the HDMI board compatible with a system that has the DVStorm card?
According to our product planning roadmap, the following hardware platforms will be supported by the next major release of EDIUS in Windows XP 32-bit editions, Windows Vista 32-bit editions and Windows Vista 64-bit editions:
• IEEE 1394 (Generic OHCI)
• ACEDVio
• EDIUS NX Series
• EDIUS SP Series
• EDIUS SD/HDLE/HD Series (RX-E1)
Windows Vista compatible 32-bit and 64-bit hardware drivers for the EDIUS NX series, EDIUS SP series and EDIUS SD/HDLE/HD series will be available with this next EDIUS release. OHCI and ACEDVio will continue to use the native OS drivers. At this time, we are still determining if it will be feasible to provide support for Windows XP 64-bit editions on the above hardware products.
The following hardware platforms will not be supported in Windows Vista, and will remain supported up to EDIUS v4.x, under Windows XP 32-bit editions only:
• DVRaptor RT2 Series
• DVStorm Series
• DVRex RT Series*
• DVStorm XA Series (China only)
• EDIUS DVX Series (Europe only)
*DVRex RT Series is unofficially supported in EDIUS v4.00 to v4.24 – it is not supported at all in EDIUS v4.5 and later.
We hope this clarifies our position with regards to EDIUS compatibility with the Windows Vista operating system. We welcome further discussion on anything that is unclear concerning our Windows Vista support roadmap for EDIUS, right here on the forums.Jerry
That would mean a dual-boot or some other multi-platform virtualisation. Since you own a DVStorm, you're entitled to a $300 discount on HDSTORM or HDSTORM Plus.
Perhaps I'm missing it, but is there firewire control on the HD StormPlus option?
Or are we to rely on OHCI control for firewire decks and input? And if so, is there a control option from Edius5 for choosing OHCI?Documentaries and Art Projects
Hudson Valley, NY
i7 8700K @ 3.70 Ghz/16 gb RAM
windows 10
284 gb SSD boot drive
2 TB work disc
2TB storage disc
EDIUS 9.52.6031
that's what i thought...many thanks for the clarification.Documentaries and Art Projects
Hudson Valley, NY
windows 10
2 TB work disc
2TB storage disc
EDIUS 9.52.6031
Originally posted by GrassValley_KH View PostHDSTORM doesn't feature any FireWire (not even with the bay).
You can call up OHCI from within the software for your capture needs. Or, if you need realtime FireWire output, you start/switch to an OHCI project setting. Otherwise, capture with FireWire, edit with HDMI output.Main System. MSI G33m Motherboard, Intel Q6600 CPU, 2GB Ram, GeForce 9500GT, 7200rpm System drive. WinXP. Lots of external eSATA drives.
HDStorm has nothing to do with the capture process via firewire...
scene detection and camera control is working normally...
the only limitation is that you can not have preview on an external monitor during the capture processAristotelis Bafaloukos
BEng (Hons), MSc, MBCS
Ctrl+Alt+Delete
Originally posted by harveylexton View PostIf you have a quad core proc and ohci then why would you need an Edius card at all, my laptop core 2 Vaio renders pce in lightening time so no real need for card based renderer or file conversion to MPEG 2 etc
For Tobe, Edius 5 with DVStorm working
DVStorm working on Edius 5 instructions (discovered by a friend of mine)
Install Edius 5
Install Edius 4.6 (with DVStorm drivers)
Open 4.6 and create your preferred DVStorm setting, close 4.6
Open Edius 5
The Storm setting is now active
Place a clip on the timeline
Voila!! DVStorm with analog output
WAiting confirmation from users...Last edited by moffwalter; 10-22-2008, 05:45 PM.
interesting..thanks...any confirmation from other users?Documentaries and Art Projects
Hudson Valley, NY
windows 10
2 TB work disc
2TB storage disc
EDIUS 9.52.6031
extremelly interesting!!!Aristotelis Bafaloukos
Ctrl+Alt+Delete
