64-bit
    Put 4Gb of RAM in and try Vista x64 again. If you can't get Edius to work faster (4 or 5) than XP then your Vista setup is incorrect. And I mean noticeable faster.
      Yep, I recommend at least 4GB with any flavor of Vista. It eats 1.6GB idle after a fresh boot (Vista x64) and it's probably hitting your cache if you launch EDIUS.
        Vista isn't significantly more memory-hungry than XP was, the reason why a Vista system is using more memory immediately after booting is because Vista caches much more aggressively. If the memory is needed by an application, Vista will free it up.
          Enable then disable Aero and watch the memory usage :)
          ~300MB in use.
