Softe Audio Converter for AC3
  • Softe Audio Converter for AC3
    Anyone use this?
    Just bought it, and it will convert all small files but does not seem to recognise the 1hr 30 min .wav that I create when encoding elementary m2v stream from procoder. Tried exporting the same audio with Pcoder's PCM exporter as well, but no luck. It's like it does not like the large size but there is nothing I can find in the help files to suggest that this might be a problem. Program is bought and paid for, unlocked with official registration code this am.
    Anyone got any ideas?
    Thanks,
    Chris
    Does it say anywhere about a time limitation?
