"N" and "M" now cut clip and leave the gaps. They add clips,if I use ALT+n or ALT+M. I couldn't find how to return default settings, though I pressed every default on application settings. Guys, please, who came across the problem, help.
Stuck with "N" and "M" disfunction
sounds like your keyboard shortcuts got corrupted
go to the keyboard shortcut menu under customize and click defaultAnton Strauss
let me see if I understand correctly
lets say you place two 4 second clips next to each other on an empty timeline for testing
now you move cursor to the middle of clip1 and press M, the clip is trimmed to the cursor position and a 2 second gap is created between it and the next clip, if yes, then this is working perfect
now, do the same again with two 4 second clips, this time press Alt+M at the mid position of clip 1, the result should be the clip 1 is trimmed at this point and clip 2 moves up to close the gap and 6 sec should remain on timelineAnton Strauss
