We have a second monitor and the preview window appears in full screen on the sceond monitor covering the bin abnd affect tools. How do I toggle out of that view. I tried all the buttons, I must be overloking something or there is a problem Anyone have a solution?
Toggle between Preview Window and Bin Window
Please tell us - the h/w, s/w, OS, etc ... we can't diagnose anything with that description. Thanks.TingSern
Did you try "Shift+Alt+L" ? This should give you a "Normal" dual or single display layout.
With "H" you can toggle the various "Effects" "Information" and " Marker" windows, and with "B" you can hide and show the "Bin"
But of course you knew all that from your manual (PDF or Printed or "F1")
P.S. of course I assume you use Edius 4.x, My self came from 2.x to 4.x so in case of version 3.x I can't confirm this works ...........
