Missing Bin
  • Missing Bin
    Fixed! 4.61
    george
    Junior Member
    Choose the normal layout or a saved layout to bring everthing back fast.
      Thanks SR I did try that but for some reason that didn't work either! Wierd
      Anyway changed to 4.6 and it popped up again.
        If you are talking about the video bin, just hit b on the keyboard and it should return or disappear.
          There are some occurrences in which hitting b will not bring it back. FYI
            Thanks. I have not run into that....as of yet.
            I'll amend my statement to try using 'b' first, and then if it does not work choose the normal layout method.
