im having a real hard time with my JVC everios .TOD files. I know Edius supports them out of the box but I still use DV and the .TOD files are too clunky to edit with. I cant use ProCoder to convert them. Itried using Edius to convert them to Canopus HQ then use ProCoder to convert them to DV but I kept getting a paramerter error in ProCoder. What is the best procedure for converting .TOD files to DV?
.tod advice
Rando, te has fijado que Edius no reconoce la fecha/hora de creacion de los .tod?
Alguien sabría decirme si esto tiene solución?
traduccion de google:
Rando, you've noticed that Edius does not recognize the date / time of creation. Tod?
Someone would know tell me if this solution is?haciendo de conejillo de indias para grass valley
yes I found the .tod files clunky to edit with.
All I did was right click on the file in the browser and choose convert file, the resulting HQ file edited with the fluidity we have come to know from Edius.System 1 - Win7 64/Edius 5.51/Asus P8/8Gb RAM/RAID0/i7 2600K OC/nVidia Quadra 600
