cheapest solution downrezz from 1080i into Edius
  • cheapest solution downrezz from 1080i into Edius
    What is the cheapest solution for in-camera downrezzzing HDV footage to SD directly into Edius by firewire? I shoot on FX1 and edit in DV and don't want to beat up the camera so badly capturing footage for my upcoming HDV-SD projects. Is the low-cost solution to buy a low-end Sony (or other) HDV camcorder for playback rather than a full blown HDV deck?
    If so, what's the cheapest model?
    Any real world gotcha's with going this route?
    Tobe
    Hudson Valley, NY
    i7 8700K @ 3.70 Ghz/16 gb RAM
    windows 10
    284 gb SSD boot drive
    2 TB work disc
    2TB storage disc
    EDIUS 9.52.6031
    i would capture all material to canopus hq hdv and then open the files in a edius dv project. Takes more computer power and Hdd space but you are able to switch your project to hdv whenever you need. If you have a good computer you can do the entire project in hdv and then just export it to dv or mpeg or whatever you need...
      But I still am looking for the cheapest way to playback the HDV tapes. Thanks,
      Tobe
      Hudson Valley, NY
      windows 10
      2 TB work disc
      2TB storage disc
      EDIUS 9.52.6031
        Yes, the cheapest solutiohn would be a less expensive camera. I really don't know anyone that has a deck. I know for the Canon solution the new HV20 is a fantastic $1,000 camera. We are getting one for our "deck"
          agreed... A deck is very confining and a lower cost camera, which is usually less expensive than a deck, works well not only as a deck but also as a back up camera if you are ever in a pinch. :)
            Hey Pat...I got one of those suckers for $978 online from Circuit City to use as a deck and for the tight/wide shot in a hunting 2 cam scenario....the trackers in africa are gonna love it. It really does just fine in good light and for the price makes a nice deck. Cheap cams are the way to go IMHO
              Can the Canon HV20 lovers confirm that it will properly downrezz Sony-shot 1080i from the camera via firewire to 16x9 SD??
              Hudson Valley, NY
              windows 10
              2 TB work disc
              2TB storage disc
              EDIUS 9.52.6031
                I ended up buying a Sony HDR-HC7 from Amazon (refurb) and am very happy with it...downrezzes like a charm, and the image (single CMOS imager) is surprisingly robust...maybe it'll have some 2nd camera functionality as well as use as a playback device.
                Hudson Valley, NY
                windows 10
                2 TB work disc
                2TB storage disc
                EDIUS 9.52.6031
