As the latest FLASH player now takes H.264 files I thought I would tinker abit with it.
I encoded out Canopus HQ 1440/1080 files and put it into the FREE Mediacoder encoder to make the CBR 1.5mbps H.264 files.
I did some tests with QT players encoding but I could get better results with Mediacoder and boy is it fast. If you are running a Quad it will max out all 4 cores when rendering the file. Encoding underwater stuff really tests out the codecs - encoders. Uptop stuff can be encoded at much lesser rates for good quality.
If you want a look you can go here and see some of the clips and you can watch then full screen but you need a good net connection for them to play reatime or you may have to let them buffer abit.
www.hdvunderwater.com
